Re: Starts and quits (Farmall B)
Posted by teddy52food on August 13, 2008 at 06:50:50 from (209.237.111.169):
In Reply to: Re: Starts and quits (Farmall B) posted by ScottyHOMEy on August 12, 2008 at 20:39:40:
If he was 180 off , it would never start and run. Try choking it as it dies. If it picks up again, the carb is plugged in the jets. Make sure you have the wire from the switch to the coil is tight. (battery ign)
Today's Featured Article - History of the Nuffield Tractor: Part 2 - by Anthony West. In February 1953 production of the ETC T.V.O engine started, ready for the March 1953 press announcements. The new TVO engine had a number of improvements which resulted in a 10 per cent more power (43bhp as against 38 bhp on the earlier engine) and 10 per cent more fuel economy. Some of the improvements are listed below: Redesigned combustion chamber, improved spark plugs and positioning, plug size 14mm(earlier size 18mm). ... [Read Article]
