Posted by Bob S. on August 13, 2008 at 10:38:57 from (68.113.237.237):
Howdy Got my wiring straightened out---thanks guys. Now for the next problem (issue) (challenge), I finally was able to repair my welded together steering shaft u joint (hours of grinding, filing and hammering, a new cross and caps, some JB weld for the low spots where I got carried away with the die grinder, and she's good to go). Took the cover off the steering gear box did a visual check, gears looked good, topped off the grease and covered it back up . Whats happening now is the steering shaft wants to "walk" back and forth as I steer from one direction to another. I've tightened the shaft collars and u joint as tight as possible and turning the steering wheel just pushes them around on the shaft. Anyone know what might be going on here? Thanks Bob S.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
