Posted by rustyfarmall on August 13, 2008 at 12:43:01 from (209.152.78.71):
In Reply to: M steering posted by Bob S. on August 13, 2008 at 10:38:57:
I can't think of what it is called exactly, but on the front of the steering box, in-line with the steering shaft, there is a cover with a large hex shaped fitting made right on it. Directly behind and inside this cover is the thrust bearing for the steering shaft. That cover needs to be tightened up to put a pre-load on the thrust bearing. If the cover is not tight enough, you will experience the symptoms you are describing.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
