Re: More 856 PTO clutch ???'s....
Posted by the tractor vet on August 14, 2008 at 06:00:22 from (76.212.239.80):
In Reply to: More 856 PTO clutch ???'s.... posted by Dan Swanson on August 13, 2008 at 19:40:17:
Well FIRST , ya had best get a I T manual next go to your friendly Case I H store and buy the test fitting for the PTO unit then buy a GOOD hyd. pressure gauge that will read atleast 600 lbs . If the PTO unit has been slipped much then myself i would rebuild the clutch packs and here again one MUST read the book on how to do it OR you can have more problems. Since you want to run a BIG brush hog then i would install the HD. clutch pack as it has more disc's in it. And yes engine RPM has a lot to so with clutch pressure .
