Re: Super A rear wheel clamps
Posted by mkirsch on August 14, 2008 at 06:23:42 from (64.80.110.50):
In Reply to: Super A rear wheel clamps posted by SuperA-Tx on August 14, 2008 at 06:06:04:
Any safety/strength issues with using regular Grade 5 nuts on these?
Three of the four lug bolts on mine were loose on the right side! When I pulled the bolts, the threads were buggered up around the middle of the bolt from being loose. You couldn't tighten them down completely. Nuts would be tight, bolts would be flopping loose in the wheel. Previous owner had rounded the corners off the nuts trying.
Until I can order new bolts, I replaced the one lock washer with three, and used a new Grade 5 nut so I could really bear down with the breaker bar and get them TIGHT.
