Re: Super A rear wheel clamps
Posted by SuperA-Tx on August 14, 2008 at 09:40:28 from (4.90.48.123):
In Reply to: Re: Super A rear wheel clamps posted by mkirsch on August 14, 2008 at 06:23:42:
Grade 5 is what I used on mine, course thread, square head. Also used the heavy duty nuts, grade 5.
Fastenal carries them both.
Mine were messed up too when I did the restoration but the left was the bad side. At first I used the old bolts but first time I drove it I heard popping comming from the wheel. Found the bolts came loose so I tightened them down again. After they came loose the second time I decided I better just get all new stuff. Wouldnt want to be driving down the road and the rim and tire come off.
