Re: 560 D282 starting problem after head job....help
Posted by JF Klein Rot on August 14, 2008 at 23:14:40 from (84.80.14.234):
In Reply to: 560 D282 starting problem after head job....help posted by Clefus on August 14, 2008 at 20:12:34:
Are the injectors put in the right way the glowplug must be above the injectorline.
We had the same problem, after we turned the injectors is started with no problems and without ether.
