560 D282 starting problem after head job....help
Posted by Clefus on August 14, 2008 at 20:12:34 from (98.21.79.62):
Ok .from a previous blown head gasket post.....had head magnafluxed and surfaced.....I installed a new ex. valvespring to replace a broken one....everything else seems ok....I had the injector bodies out and cleaned buildup off the injector area with a scotchbrite on air die grinder...was this a no-no??
cont. -- I torqued head bolts....set valves to .026 -- feelers didnt have .027...set on a loose .026...
Put manifolds back on and want to get running before filling with water ...
I hooked up fuel lines, bled both filters .....
I try starting and with ether ( always used a whiff in the past) and throttle w/o --get black smoke ..starts a little to white...kinda sounds noisier than it used to but wont fire..keep killing baterries--- what could be the ailment ??
Thanks dave
