8 degrees isn't far off for doing the adjustment. Unless the magneto is rotated all the way against the engine block, you should be able to just set the timing. If not, the governor gear will need to be remeshed as Gene said. It isn't likely it "jumped a tooth". If it is off, the last person that worked on it assembled it wrong.
On the carb, somebody probably just replaced the original with what he had on hand.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
