Posted by Tim Powell on August 15, 2008 at 03:07:11 from (72.228.48.232):
I am restoring a 1941 Farmall "A"; First, the magnito impulse coupler trips about 8 degreas "before" TDC? and before # 1 is in position, Could the impulse timming gear jump a tooth maybe? Also it has a "distillant" (kerosine)type carb but has always run on plain gas. Could somebody else have changed this carb or is this a standard fix replacement?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
