Re: 560 D282 starting problem after head job....help
Posted by SamC-VT on August 15, 2008 at 10:58:00 from (66.220.228.165):
In Reply to: 560 D282 starting problem after head job....help posted by Clefus on August 14, 2008 at 20:12:34:
The only time I've had to pull my 560D was due to poor batteries. Simply cracking open the lines at the injectors has always been enough to bleed the system. Sixty second of bending over to hold that glow plug switch is a looong time, but it always does the trick on mine when the temp is above freezing.
It does take a good battery to spin the diesel fast enough - took me a while to learn this coming from gas engines.
