Re: Farmall A , 1 problem; 2 questions
Posted by Mike Farmer on August 15, 2008 at 11:11:42 from (86.31.84.127):
In Reply to: Farmall A , 1 problem; 2 questions posted by Tim Powell on August 15, 2008 at 03:07:11:
Its been running like that so I doubt if its a tooth out. I suggest that you simply go through a retiming sequence. If its mechanically "out" I think? it is possible that the pawls may be tripping early in your mag. Just maybe worth a try. With it tripping that early you just might feel like disconnecting the plugs if you are going to turn it over by hand. Good luck MTF
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
