Re: 560 D282 starting problem after head job....help
Posted by Owen Aaland on August 15, 2008 at 15:09:26 from (65.161.86.52):
In Reply to: 560 D282 starting problem after head job....help posted by Clefus on August 15, 2008 at 14:26:16:
Clefus said: (quoted from post at 14:26:16 08/15/08) THANKS for all the replies....
......manual says those pumps self bleed.....guess not....
thanks again for the replies......
The pump IS self bleeding. The injectors are not. That is why you need to bleed the air from the injectors. If you had pulled it you would eventually get the air bled through the injectors and it would have started. It can take quite a while if there is much air in the lines.
