Tim Powell here again; Farmall A timing problem
Posted by Tim Powell on August 15, 2008 at 17:51:37 from (72.228.48.232):
Ok; I took your advice and thanks. I spent a couple hours jury rigging a caliper that would measure the clutch housing ring gear diameter. Then I measured the degrees off before TDC the mag tripped and laid that out along the circumference and got 14 degrees. The 8 was bad guess. I've been through the timing sequence 30 times by now and not sure of anything anymore. I would have already started tearing the front end off but I had to go to a local Ag fair this PM.
