Re: Tim Powell here again; Farmall A timing problem
Posted by Bob on August 15, 2008 at 17:54:22 from (69.178.228.68):
In Reply to: Tim Powell here again; Farmall A timing problem posted by Tim Powell on August 15, 2008 at 17:51:37:
Are you saying you can't retard the mag enough to get the impulse to trip at the correct timing, TDC???
In other words, the governor/mag drive is too far advanced?
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
