656 bull pinion shaft wiggles
Posted by karl f on August 15, 2008 at 20:33:38 from (4.254.84.154):
Wanted to adjust the brakes today, and discovered one of the bull pinion shafts wiggles pretty good by hand. :(
what am i in for? I'm afraid if there is a way to target just the shaft, I'll still end up dismantling the tractor, because another bearing will be shot, or i'll find the differential damaged as well.
My record of opening a can of worms is pretty consistent, adjusting the valve lash turned into replacing a couple push rods! good now, knock on wood.
thanks
karl f
