Re: 656 bull pinion shaft wiggles
Posted by John G. Hasler on August 16, 2008 at 10:40:28 from (207.230.223.204):
In Reply to: 656 bull pinion shaft wiggles posted by karl f on August 15, 2008 at 20:33:38:
> My record of opening a can of worms is pretty
> consistent, adjusting the valve lash turned into
> replacing a couple push rods!
You got off easy. In my case it turned into replacing the cam.
