Re: 560 D282 starting problem after head job....help
Posted by J.J. from Afton on August 15, 2008 at 21:15:04 from (66.41.82.17):
In Reply to: Re: 560 D282 starting problem after head job....help posted by Rootsy on August 15, 2008 at 07:28:00:
Hogwash. As long as you know what your doing, pay attention and do everything in the right order, pull starting it works just as well. We had to pull start my 560D after a fresh rebuild up at tech school cause the starter was junk and dealer had none on hand. Pulled it to get oil pressure, than cracked the injection lines bled em all, retightened em and pulled it around for about 3 minutes and it fired right off. Weve had to pull start 6 or 7 tractors at tech school, theres even been some real old time tractors we started off another with a flat belt.
Only time equipment is damaged or people are injured is when something wasnt done right or somebody doesnt know what they're doing.
