#1. Throw the ether away... bad juju in glow plug engines...
#2. Crack all of the fuel line fittings at the injectors.
#3 crank until you have fuel there and no air coming out.
#4 tighten lines but not all of the way, let them seep a bit to continue bleeding air if it may be present
#5 Lean on the glow plugs for 60 seconds before turning her over - helps to know that all 6 glow plugs are in fact working.
Once it fires (assuming everything is put back together correctly) you can go back and bleed all of the lines while it is running to make sure all of the air is out.
Sorry Allen and Hugh but pull starting a tractor that has just been repaired can lead to bad situations. Either in broken parts and or run aways and in turn destroyed equipment and broken bodies...
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
