Re: IH 300 Utility 6 volt alternator wiring questions
Posted by Janicholson on August 16, 2008 at 06:36:03 from (66.173.50.71):
In Reply to: IH 300 Utility 6 volt alternator wiring questions posted by fxt on August 16, 2008 at 05:52:38:
Bob M diagrams are the ones to choose.
You will need a diode placed in the line from the #1 terminal to the power source. The diode will have its band end facing the alternator if Negative ground. and toward the voltage source if positive ground.
I believe your battery cables may be too small. O gauge wire (with strands of copper adding up to the size of a first grade pencil) will help dramatically. JimN
