NO ETHER, NEVER!!! Bad, bad, dog, no biscuit for you... Ether is VERY dry, WD-40 or similar is much easier on the engine. Even a rag soaked in gasoline or similar placed near the intake (don't let it get sucked in) has known to work.
Hugh: I use a circulation type heater here in Louisiana. It may only get into the high 20's in the dead of winter, but it may as well be Siberian Tundra with an old IH engine. I plug mine in from about November until February as needed (it has been in the 80's for Christmas...)
Clefus: Make sure you go somewhere like NAPA an get a HEAVY DUTY momentary switch. I use a 30A fuse and a 30A or 40A momentary PB through 10ga wire, on 4 glow plugs. I usually let mine heat up 30-60 seconds, even if it is 105 outside. Starts quick and smokeless. With 6 (functioning) glowplugs, I would use something like a Ford starter relay actuated by a switch of your choice if the high-amp PB is cost prohibitive.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
