super c oil leak...
Posted by kelsh on August 17, 2008 at 18:18:44 from (98.243.103.90):
My super c 123 engine is burning oil. I checked the compression dry and all read close to 120 dry and 160 wet. After running it a few minutes the blue smoke builds in the exhaust and I have a steady slow running stream of oil dripping through the exhaust manifold gasket. The oil is bleeding at the center two ports and runs down the motor behind the carb. I had the head and valves redone. I assembled it with a new head gasket and copper spray. Any ideas whats wrog? I just removed the valve cover and with a flash lite looking through the valve spring I noticed where the valve stem passes through the head and valve guide there isnt any type of rubber boot on any valve stem. Is there suppose to be? Thanks! Sorry this is so long.
