Posted by Wayne in MN on August 17, 2008 at 20:42:41 from (68.119.27.241):
In Reply to: super c oil leak... posted by kelsh on August 17, 2008 at 18:18:44:
That much change in compression from dry to wet readings tells me the rings are in tough shape. Many times if you just do a valve job it will cause the rings to go from bad to worse. I think you are in need of a complete overhaul. To know more accurately if the rings are worn, get a cylinder leakdown tester and see what percent of the compression loss is past the rings.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
