Farmall M serious problem
Posted by Mike Farmall M on August 18, 2008 at 16:10:32 from (66.159.147.135):
I have a 46 farmall m that i pull with in antique pulls and the other day i was backing to the boat and the tractor started to die like it wasnt getting fuel so it shut off. the gas was on it was getting fuel. we pop started it checked the points and opened a screw on the carb a bunch of gas came pouring out. what is causing the problem shutting off? i have a magneto but it is canceled out with a coil and an external condenser. i have a 12 volt battery but i am only charging at 6 volts with a generator. it also sputters at times when reved up.
