Re: Farmall M serious problem
Posted by Janicholson on August 18, 2008 at 17:17:30 from (66.173.50.66):
In Reply to: Farmall M serious problem posted by Mike Farmall M on August 18, 2008 at 16:10:32:
Charging at 6v will not actually put a charge in a 12 V battery. Disconnect the generator and run only the battery. Make sure the battery is fully charged before each evening, and all will be well. JimN
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
