Posted by Janicholson on August 18, 2008 at 17:36:54 from (66.173.50.66):
In Reply to: update posted by dianah on August 18, 2008 at 15:05:07:
The PTO lever is indexed with a notch on the linkage when pulled back, the button is pushed and it is locked into position. If the pawl and notch are worn, a bit of weld and a file should make it right. Running wide open is just fine for PTO speed. 180 may be the t-stat setting. (I would back wash the radiator to assure it is flowing air) I would also check the radiator for flow by feeling it all over (grill off is best) to assess tube flow when heated up) Shut it off to feel the back side and avoid the fan. JimN
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
