Posted by Rford on August 18, 2008 at 19:06:45 from (24.27.133.84):
I'm not a tractor-guy. I'm trying to help a friend get his 460 working. The #1 issue now is the lines that run under the seat into a small square block at the rear of the tracor have huge leaks where they meet the "box". The one line has a coupling at the box that someone has scab welded. The other is just cracked..again, right at the box so there's no way to cut and use fittings. It looks to me like I have two choices. 1. Find a replacement set of lines and "box" or have them brazed etc. by some local shop....now, I guess heres my question...is this repair something that is "common" or "easy" or whatever you want ot call it. Or should I be searching the tractor used parts for a used part.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
