Because the leaks were right where the lines met the valve regulator it wasn't a deal where I could just cut the bad part out and use hoses. So I disconnected the leaking scabbed fitting and cut the line on the other side and took the valve to a hydraulic shop. They are going to remove the old fitting from the one side and the brazed line from the other. That will leave me with just the valve and then they'll tap the valve and insert two new fittings. That will allow me to connect the valve to the lines with a short hose on one end and a compression fitting set up on the other....
The machine work will be $100. I'm sure the hose and fittings will be another $100....oh well.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
