Re: Farmall 140 leaking gear oil
Posted by Hugh MacKay on August 20, 2008 at 18:18:42 from (209.226.247.113):
In Reply to: Farmall 140 leaking gear oil posted by PaulnNC on August 20, 2008 at 14:47:09:
Paul: The weep holes are designed to drain off any oil that leaks by the rear axle seals, before that oil gets to the brakes.
Check the fill to level plug first, the transmission may be over full. Read my instruction to Diana, about half page down. Fill to level plug is just below front tip of left fender. Kind of hidden behind brake activation rod.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
