Re: Farmall H engine bearings� removed rod caps
Posted by JT on August 21, 2008 at 18:11:18 from (72.61.169.83):
In Reply to: Re: Farmall H engine bearings� removed rod caps posted by Joe Henry on August 21, 2008 at 15:56:21:
That looks like aluminun babbit on the crank. So you do not take anymore steel off with emory/sand paper, go to your local radiator shop, buy a little pure muratic acid. start dabbing it on the aluminum, with a cotton swab, it will eat the aluminum off the crank. Is a long process, and will clean oil off anything it touches and will flash rust. so be patient. Be very careful, thought, muratic acid is nasty stuff, and the gas it gives off when eating the aluminum is strong, will burn your eyes, and make it hard to breath. But will clean the steel without taking any more off and making clearances wider.
Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
