Re: Farmall H engine bearings� removed rod caps
Posted by PaulW_NJ on August 21, 2008 at 21:22:27 from (72.76.239.189):
In Reply to: Re: Farmall H engine bearings� removed rod caps posted by JT on August 21, 2008 at 18:11:18:
Something is mixed up there. You would not use an acid. Muriatic acid, which is hydrochloric acid, will eat away at the steel of the crank. I"m not sure what it will do to the aluminum. I do know that aluminum will be dissolved by sodium hydroxide, or lye, without the steel being touched.
