The stalling is not related to the oil pressure if the coolant is full, and at 150 as stated. The oil pump probably has a warped cover and can be fixed pretty easily by using a flat plate of glass to "flat sand" the cover to make it flat again. The end play should be between .0005 and .001". The pump does not need to be removed to do the repair, but the pan does need to be dropped. Be sure the long bolts in the end of the pan go back in the same holes, and are not over tightened. If this turns out to not be the problem, the engine bearings (cam, rod, main) might be worn enough to be the cause. Many an H or M has had less pressure for years WO issues. So it is your call. The gasoline cap may have a plugged up vent in it causing fuel starvation at an hour into the running. Coils and condensers are also heat sensitive, and prone to cause that symptom. I would see if it has good 1/4" blue spark when it quits before any other diagnosis. JimN
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
