low oil pressure in 1939 farmall H
Posted by Rich ORourke on August 21, 2008 at 22:45:45 from (68.163.13.135):
My farmall H 1939, starts at 40 psi oil pressure, in 30 minutes it drops to 20 psi. at 45 minutes it drops to 18 psi, at one hour it drops to 16 psi and then stalls. I would be grateful for any suggestions. The temperature of the engine and radiator stabilizes at 150 degrees. And yes there was plenty of oil in the engine.
