If the freeplay is at one inch (from the edge of the platform, there is nothing that changing the fingers will fix. If there is lost motion in the cross shaft, or clevices in the linkage, they will cause issues, but should be adjustable enough with a new disk to work. If there is play in them, putting new pins in the clevices may help. Again if the freeplay is OK, the clutch should release. A warped hub on the friction disk, will cause dragging of the clutch. My test of the system requires it to be outside in a safe clear location. Pointing at a clear stretch of open lawn, or road/field, with the tractor shut off, put it in 4th gear, push the clutch in all the way to the stop, Start the engine and put it at 1/4 throttle. Start letting out the clutch slowly. If it takes right off within an inch of release from bottomed out, the adjustment is wrong. If it doesnt move until the pedal is 3/4ths the way out, the adjustment is OK. If it drags so much that the tractor cannot be put into gear while running, and the engagement point is at the 3/4 travel area as above, I would suspect a warped friction disk. The specification on the finger adjusters is that they be within .002" of each other measured from the disk hub to the tip that touches the release bearing, with a depth reading caliper and good measuring practice. (this spec. is an experience based number, not from a book)If the disk was put in backwards (springs in the hub to the flywheel) it will not release, and the disk must be turned around. Good luck, JimN
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
