Re: low oil pressure in 1939 farmall H
Posted by RustyFarmall on August 22, 2008 at 11:36:31 from (209.152.78.71):
In Reply to: Re: low oil pressure in 1939 farmall H posted by Paul Shuler on August 22, 2008 at 08:49:30:
Yep. Try the cheap fix first by removing the fuel cap. If that cures it, you need a new cap, but be sure to get a vented cap. If removing the cap doesn't fix it, replace the ignition coil.
Has the tractor been converted to 12 volts by chance? If so, the resistor may be bad, and that is why the coil is failing.
