Posted by Brad in WI on August 22, 2008 at 20:15:11 from (69.23.75.255):
On my MD, it runs and seems to run decent but I have no fuel pressure at the gauge. Photo shows pressure at HIGH idle
I have already changed fuel filter. I do have a custom filter setup as shown in this pic.
I have good pressure going into the plunger fitting but hardly any showing on the gauge. I also have a bunch of pressure going into the return line. This pump is a TD-14 pump mounted on a 1947 MD. What are some things that I am overlooking. I know about all the fuel over the side rail and everywhere else. Thanks
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
