Re: 49 Cub wiring
Posted by Janicholson on August 23, 2008 at 09:52:29 from (66.173.50.60):
In Reply to: Re: 49 Cub wiring posted by Michael Adams on August 23, 2008 at 06:39:34:
A regular VR either 4 pole, or 3 pole has a cutout relay inside it. I will bet yours is being used as a cutout relay, and can continue to do so wired as it is. The field terminal would be unused, as would an internal component, but the cutout portion would work OK. The light SW is (from full CCW) Low charge High Charge, Dim, Bright LHDB.
There are two parts to the switch one to control the lights, the other is a grounding system for the F terminal of the gen. Do not cross them up, or things will not work. JimN
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
