300 Wiring
Posted by Craig T on August 23, 2008 at 16:45:48 from (204.11.176.166):
We are restoring a 300 with factory 6v. We bought a new wiring harness from OEM and installed it according to the instructions.
The first time we tried to start it, the wire going from the "bat." term. on the reg to the gauge and the wire from the "L" term. to the starting switch both burned up when neither the switch nor the lights were on. We double checked the wiring and are sure we didn't hook them up wrong. We then got a new regulator and replaced the wires. We thought we had it fixed until today the same thing happened.
The tractor doesn"t turn over very well for the size of the new battery. We were wondering if a faulty solenoid on the starter could be causing our problems. Any information or advice is appreciated.
