Re: 300 Wiring
Posted by Janicholson on August 24, 2008 at 05:13:09 from (66.173.50.32):
In Reply to: 300 Wiring posted by Craig T on August 23, 2008 at 16:45:48:
The L terminal on the regulator is internally connected to the bat terminal. Thus both are places that will have (negative(hot))battery voltage applied when a battery is installed correctly. On your tractor the L terminal If you use it, should connect to the input terminal of the light switch, not the starter switch. If it was connected to the starter relay at the big terminal that is attached to the starter motor, it will burn immediately. The starter would be trying to operate using that #10 wire, and it would fry. Tell us more after looking over the diagrams. JimN
