Posted by Owen Aaland on August 24, 2008 at 05:02:00 from (65.161.86.52):
In Reply to: 656 WILL NOT PULL posted by Steven f/AZ on August 22, 2008 at 08:24:19:
Steven f/AZ said: (quoted from post at 08:24:19 08/22/08) You can always weld the TA solid if you are trying to get going as cheap as possible.
To replace the TA you will need to split twice, and since it doesn't move at all I assume the TA clutch is out as well. While you have it apart you will need new seals, new gaskets, new TA clutch parts, new TA, and just as well replace the main clutch while you're in there. Looking at quite a few $$ just for parts and lots of labor charge if someone else is doing it...
This style TA always transmits torque through the planetary gears in both TA and direct drive position.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
