Re: Adding 3pt Hitch to 340u with Loader Hydraulic Plumbi...
Posted by BMD on August 25, 2008 at 07:08:22 from (65.254.172.6):
In Reply to: Re: Adding 3pt Hitch to 340u with Loader Hydraulic Plumbi... posted by mkirsch on August 25, 2008 at 05:31:56:
Thanks for the info!
Think I am getting a better idea of how things work. The open center of the loader valves vent fluid to the return line when the loader valves are centered. Thats why I can not tee into supply line from pump.right?
Is the OUT port on the loader valve asm. the port the return line is connected to? I know that sounds fuuny but all the terms for ports gets confusing(OUT, RETURN and Power Beyond).
thanks again for the help.....
