You can't tee into it. It's an open center system. If you tee into it, nothing will work because the oil will always have a low-pressure path back to the reservoir.
The whole system needs to be one large single circuit. Run the line from the OUT port on the loader valves to the IN on the tractor's remotes. Everything will work fine then.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in
... [Read Article]
Latest Ad:
[More Ads]
