No serial plate for an H
Posted by Scott Walker on August 25, 2008 at 18:41:37 from (99.255.227.99):
I just bought an H that is complete except for a serial plate. You can see where it was removed from the left hand side of the transmission case. How would I go about identifying the year it was built and how would I order parts for it?
Thanks!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
