Re: No serial plate for an H
Posted by Andy Motteberg on August 25, 2008 at 19:16:48 from (4.143.219.153):
In Reply to: No serial plate for an H posted by Scott Walker on August 25, 2008 at 18:41:37:
Look for casting codes, a casting code is stamped into several of the cast iron parts, example: 8-25-M would mean August, 25th 1943, the letter at the end of the code is the year:
1939 - I
1940 - J
1941 - K
1942 - L
1943 - M
1944 - N
1945 - O
1946 - P
1947 - Q
1948 - R
1949 - S
1950 - T
1951 - W
1952 - X
1953 - Y
If it still has the original block, the serial number is stamped on a smooth flat spot on the block under the spark plug hole.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
