Re: Super c Stutters, dies, won't run right.
Posted by Janicholson on August 25, 2008 at 20:55:09 from (66.173.50.124):
In Reply to: Super c Stutters, dies, won't run right. posted by DieselMatt on August 25, 2008 at 20:34:15:
A quick and sure way is to attach a fuel tank from a small engine to the carb intake, clean the bowl one more time, Let new fuel in, and start it. If it runs fine, the tank, inlet to sediment bowl, bowl, valve line, and screen at the carb all need to be cleaned. If it does not change, the carb needs to be dip cleaned and blown out to clear each little port in it. JimN
