Re: rear end of H fluid level
Posted by Andy Motteberg on August 28, 2008 at 16:28:54 from (4.143.221.185):
In Reply to: rear end of H fluid level posted by dancbtmkr on August 28, 2008 at 04:24:33:
The 6 gallons you put in is the right amount. The level check plug is located on the side of the transmission housing, on the clutch pedal side of the tractor. Make sure that the tractor is parked on level ground when you check the oil level. The transmission is not supposed to be full of oil.
Andy
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
