Posted by PetePequawketfarm on August 29, 2008 at 06:59:44 from (208.125.195.154):
In Reply to: H charging prob;lem posted by PetePequawketfarm on August 25, 2008 at 10:42:53:
Thanks for all the advice. Last night after trying 2 different regulators with no success- both had external ballast resistors which my unit does not use- I put the "failed" voltage regulator back on and adjusted the spring tension on the Field side of the genny. It went from 10a discharge to 15a charge reat. After a few more adjustments on spring tension the charge rate is at 4a at idle and approx 8a at WOT with the 8V battery. I'm going to run it for now and see what happens. Thanks again Pete
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
