H charging prob;lem
Posted by PetePequawketfarm on August 25, 2008 at 10:42:53 from (208.125.195.154):
Maybe someone has had this happen. Battery finally failed on the 48H. 7yrs old. Replaced with an 8v battery instead of 6. Generator not charging. Energize the Regulator- still not charging. Replace regulator with new from local Case IH dealer. Hook up as per instructions. Hook up battery and BIG spark. Ammeter shows full discharge. It will start, run and charge @10amps at idle-more at WOT. If you leave the battery hooked up it will drain the battery in less than 1 hour. Seem to have continuity everywhere in the system when batt is connected. Replaced the starter switch and kill switch with no change in draw. Do I have a bad regulator or is it the gen? It is a Delco 6v generator. Any help is appreciated
Thanks Pete
