Re: M Carb Dumb Question Time II
Posted by Wayne from MN on August 29, 2008 at 08:12:40 from (66.228.243.49):
In Reply to: M Carb Dumb Question Time II posted by Dan Bear Kelley on August 29, 2008 at 06:35:34:
I have found that when a carb is rebuilt and put back on the tractor there is a good possibility that a tiny particle of "stuff" may get in the needle & cause it to leak at first.
What I recommend is:
1. install all parts except the fuel line.
2. open the tank shutoff and catch a cupfull of gas. shut off the valve.
3. attach the fuel line.
4. remove the small drain plug (square end) and allow some fuel to drain out by opening the tank valve again. With the float hanging down, any small particles of "stuff" will flush through the wide open needle valve.
5. replace the drain plug & all should be well.
