Re: Adding Behlen PS to 1951 M w/live hydraulic on distri...
Posted by Allan In NE on August 31, 2008 at 06:47:56 from (148.78.243.24):
In Reply to: Adding Behlen PS to 1951 M w/live hydraulic on distributor posted by Jerry Deimerly on August 31, 2008 at 05:52:10:
Jerry,
If you already have a live pump, just add a priority valve between the pump's output and the original system. The "exhaust" port of the priority valve would then be the original system's "pump".
Plumb in the steering motor to that priority valve's regulated steering port and create a new route back to the sump for the steering motor's exhaust.
There is no need for the additional pump.
Allan
